Hello again.
New problems are coming, getting our customers more and more upset, can’t read JPG files (by double click or space bars), they get bad files (corrupted or bad types) error messages.
I tried connecting directly by MacOS Finder, and ALL files opening work correctly !!
Really, we need a fix quickly, as we already have some other issues we talked about, listed here :
Up !!!
sorry, I didn’t know this was a 7 days closing post. Still error 36 here :
NetDrive version: 3.5.250
Windows/Mac Version: MacOS 10.13.4 High Sierra
Sometimes getting “error 36” and “failed to upload”, as you can see on screenshots.
Is there a way to explain / avoid them ?
Best Regards
Patrick [Netdrive_Err_36] [Netdrive_Failed_to_upload]
We really need to fix all this !!!
Regards,
Patrick
June 12, 2018, 2:10am
2
Dear lic-impact
Here it is. And please get us that fix quick. Data access is getting more and more problematic !!!Archive.zip (10.6 KB)
June 12, 2018, 5:40am
Dear lic-impact
The log level of the log files you attached is “ERROR”
I can get a few information from error level log.
Could you attach it again after set loglevel to VERBOSE and reproduce the issue?
From the log files you attached, I got the following contents
GetFileList >> Couldn’t resolve host name(6)
It failed to connect to server because host name could not resolved.
It’s better to check network environment.
June 12, 2018, 8:04am
6
Dear lic-impact
I got the file you attached.
It is a same file you attached before.
It’s a error log file not debug log file.
Also, from the log files you attached, I got the following contents
It’s already on verbose mode, as usuall…
Archive.zip (121.5 KB)
June 12, 2018, 8:42am
8
Dear lic-impact
I got finally VERBOSE mode log files.
But all read requests in log file were succeeded.
I think there was no error to open jpg file.
June 19, 2018, 8:42am
9
