Up !!!
sorry, I didn’t know this was a 7 days closing post. Still error 36 here :
NetDrive version: 3.5.250
Windows/Mac Version: MacOS 10.13.4 High Sierra
Sometimes getting “error 36” and “failed to upload”, as you can see on screenshots.
Is there a way to explain / avoid them ?
Best Regards
Patrick
HI Ysh, and many thanks for your quick response .
Log files enclosed.
Best regards
PatrickNetDrive_logs.zip (600.6 KB)
May 23, 2018, 8:27am
5
Sorry we missed your topic. Topic reopened.
Thanks a lot. Did you get the Log file I sent to you ?
Yes we can download the log file. Our engineering team will look into the issue and get back to you.
Thanks for the replay, I hope you’ll find a solution quickly, as our customers using it are getting eager :-p…
June 4, 2018, 7:22am
12
Dear lic-impact.
I’ve reviewed your log files and I found it was not written in VERBOSE log level.
Could you attach log files in VERBOSE log level again?
This is really strange as I checked Log settings, and they already are in Verbose mode.
Anyway you’ll find enclosed a news Log file.
patrickNetdrive_Log.zip (38.5 KB)
Hello, we ran into another problematic issue, as our customers bought many licences for NetDrive, they’re getting really
upset.
Basiquely, every files or directory shows the same date creation, 01.01.1970, and the modification date is correct, BUT indicates the hour -1.
you’ll find enclosed two screenshot, the Netdrive Windows and another software windows, listing the same directory and their informations…
June 5, 2018, 6:37am
15
Dear lic-impact
For saving a office file issue, I can reproduce it on my mac.
It will be fixed soon and I will notice to you as soon as fixed.
And for timestamp issue, I will review the log files you attached.
Dear Jyyoon,
Thank you for your response.
I just forgot to mention that we use DD/MM/YYYY, and we use Europe/Zurich timezone, if this can help.
Good morning people, I hope it’s all going right for you, looking forward for a fix…
June 7, 2018, 4:18am
18
Dear lic-impact
The cause of the issue for the creation time is the following.
In your logs, the creation date format is different from the last modified date.
<lp1:creationdate>2018-06-04T06:27:16Z</lp1:creationdate>
<lp1:getlastmodified>Mon, 04 Jun 2018 06:27:18 GMT</lp1:getlastmodified>
This issue will be fixed soon.
Dear Jyjoon,
Thanks for this information.
At that time, can you give me any ETA for all fixes ?
Patrick
June 7, 2018, 5:57am
20
Dear lic-impact.
I’m sorry for the wrong information.
I found that the wrong creation time is for NetDrive’s bug.
It will be fixed soon.
So, do you have any ETA ?
