Hello everybody.
Sice many months (years) i used Netdrive for Webdav conexion to my Diskstation.
Few days ago it doesn´t work. The configuration is exactly the same. It says: CONNECTION ERROR
I tried with external IP too without success.
I have exactly the same problem with my NetDrive (2.6.20 build 985).
From one day to the next, it doesn’t work anymore: ‘Connection error’.
I have changed nothing, either on the computer, the DiskStation nor the network.
Even on my desktop in the same network with the same items in the Options it works still without any problems.
I wanted also, as described above, produce a logfile. But in the Options I can only change the Log Level from ERROR to DEBUG, but there’s no VERBOSE.
So no logfile is generated.
Thank you very much!
As I want to check the dns server settings, I saw that the laptop was connected to the guest-account (instead the “full” one) on my WLAN.
The laptop desided to change the account by itself
Now it works as before and I’m happy. Thank you for your help!
