I am having a recent issue where netdrive3 will freeze after a time. When I attempt to open the folder from windows explorer, it takes a very long time to load and often will not show the folders. Usually a full reboot is needed to correct the issue. Anyway someone can help troubleshoot?
tsjeong
December 23, 2021, 1:06pm
2
Dear jeffrey-demaria,
@tsjeong see attached logs
I’ve reviewed the log files you attached. However, I couldn’t find any errors that could be problematic.
Did you register your own API Key and Secret Key?
If you use your own Google API key, the upload speed may be faster.
Please refer to below link.
NOTE: All users of NetDrive share the same Google Drive API client ID for accessing their files. If your connection suffers from slow download and/or upload please register your own client ID.
1. Open https://console.developers.google.com in your browser and log in to your google account.
2. Click 'Select a project’
3. Click 'NEW PROJECT’
If you have a project already, you can use it.
4. Input project name, Organization and Location then create it.
You need to set…
