NetDrive keeps loosing Connection
I am using SyncPro Backup and it keeps loosing the connection and showingme about 8000 files not copied because of this error. I have used Trial version of NetDrive with using my Google Drive Shared Drive as a label called H: onmy PC.
Seethe sample error created by SyncPro Backup software
Profile Name: Backup ThePannus-Pictures to Google Drive HP
Source: \THEPANNUS\TP1-Pictures\Pictures
Destination: H:\Pictures
Trigger: Manual
14-09-2019 02:33:42 PM
Error: Failed to copy from Source : Cannot copy file (53): The network path was not found
14-09-2019 02:33:59 PM
\Family (Small)\1993\1993 MISC.picasa.ini
Error: Failed to copy from Source : Cannot create folder: H:\Pictures\Family (Small)\1993\1993 MISC\ (A device attached to the system is not functioning)
Hello trendgroup.
Or refer to the following topic.
I created Google API and i tried creating a new drive in NetDrive 3. Google now fails to connect and gives error message. "Error 400
Redirect uri mismatch
Request Details
Thats all we know"
Then your NetDrive message comes “Authentication with Google Drive has failed”
I did everything to create API.
Pls advice as my trial will expire on 20th.
I need it working before that so i know what i am getting into.
Harpreet Singh Pannu
MD/CEO
Trend Consultants Pvt Ltd
eMail : TrendGroup@gmail.com
Mobile : +91 98102 06855
Request Details
Thats all we know"
MD/CEO
Request Details
Thats all we know"
MD/CEO
Could you check “redriect url” is “https://accounts.bdrive.com/oauth/” or not?
If you need more trial period, we can extend it.
Yes Application home page link is same
Application name says “NetDrive 3”
MD/CEO
We updated the steps to create client ID and secret.
For OAuth consent screen settings, refer to following image
Please make it sure that redirect uri is entered.
You need to press enter after input https://accounts.bdrive.com/oauth/.
If the redirect uri is successfully added your screen it show the uri like this image.
I have 2 gmail accounts with Shared Drive. If i create this Google API will it work for both my gmail accounts since NetDrive3 has only one place to enter ID and secret by clicking on manage.
Also, pls increase my trial period as i am still struggling with API.
How would i know if it is working or not. Can i check it.
MD/CEO
If you choose Public application type it will work for both of your gmail account.
I extended your trial for another week. Thanks for trying NetDrive.
Thanks for extending trial.
How can i check if API is worming?
I am still getting error messages using SyncBackup after i have made Shared Drive as Drive letter. “Error: Scan failed (1006) The volume for avfile has been externally alteredvso that the opened file is no longer valid”
MD/CEO
