my problem is the same with this one,
- Open Command Prompt as Administrator
- Change directory to C:\Program Files (x86)\Bdrive\NetDrive3
syshelper.exe i cbfsinst.dll cbfs.cab NetDrive3 "C:\Program Files (x86)\Bdrive\NetDrive3"
I get -2 not 0!
syshelper.exe i cbfsinst.dll cbfs.cab NetDrive3 "C:\Program Files (x86)\Bdrive\NetDrive3"nd3svc_Calibre-WebDAV.zip (5.0 KB)
All log files.
According to your log file, nd3svc_Calibre-FTP.log it seems that your drive Calibre-FTP mounted and works.
Please try again with Calibre-WebDAV.
It’s still the same
I click the press “browse” , that’s ok! But can’t connect as a net drive successfully!
从 Windows 版邮件发送
Your upload includes only error log for Calibre-WebDAV. Please send us debug log file of Calibre-WebDAV.
NetDrive3_Himan^^.zip (27.4 KB)
I found a error in the file you attached.
NetDrive filesystem does not installed
I guess you might be using NetDrive on arm cpu machine.
Or some program like as anti-virus or anti-malware program could banned installing the filesystem of NetDrive.
Please check cpu.
Dear cg0808,
It can be blocked by some programs like Antivirus or Anti-malware softwares. If you use these softwares please unblock or add exception.
If you are not using any antivirus software you can try re-install NetDrive filesystem driver.
syshelper.exe i cbfsinst.dll cbfs.cab NetDrive3 "C:\Program Files (x86)\Bdrive\NetDrive3"Regards
