aautry
September 2, 2022, 8:26pm
1
Continuing the discussion from I have a few questions - NetDrive3 :
The Microsoft Office multi-user feature does not seem to be working for my team.
When two users open the same Microsoft Word document neither user’s program shows that it is in read-only mode. Both users are able to make changes and save the file. Only one user’s changes are visible upon reopening.
Per the I have a few questions - NetDrive3 discussion we have confirmed that our Google Cloud Storage account is seeing the temporary files with names starting with ‘~$’.
User setup:
NetDrive3 - 3.16.539 (in trial)
User 1 - Maintainer and Admin
OS: Microsoft Windows 10
MS Office 2016
User 2 - Maintainer
OS: MacOS Big Sur 11.0.1
MS Word for Mac (16.16.27)
We need to check the issue with log files. Could you send us debug log files of both User 1 and User 2 ?
aautry
September 8, 2022, 7:46pm
3
MS-MultiUser-User2-MacOS.zip (2.9 MB)
MS-MultiUser-User2-PCOS.zip (1.6 MB)
For this test:
User 1 is using Office 365 on a Windows 10 machine
User 2 is using MS Word for Mac (16.16.27) on MacOS Big Sur 11.0.1
Sometimes the multi-user feature seemed to work, but there were a few instances where it did not.
aautry
September 14, 2022, 7:55pm
Checking in to keep the ticket open. Any updates on this issue?
September 21, 2022, 7:56pm
5
