I am trying to map a network drive in a mac, and I get this if I map it as a network drive or local drive??
Cheers
Josh
Cheers
Josh
The message means NetDrive process which handles mounting does not executed.
Did you changed SIP of your Mac?
hello, that didnt fix it
is there anything else that could cause it?
I can explore the data manually, but want to map it as a SMB
It’s not a debug log files. Please change log level to VERBOSE and reproduce the issue.
logs have been changed to verbose, then clicked back to main page, and reran the request to mount the drive.
as attached.
logs.zip (5.4 KB)
Hey mate
Any update?
Josh
From the log file it seems that NetDrive cannot create pipe for communication with child process which mounts remote storages.
[2023/07/24 17:24:34.772] [DEBUG ] [ 2] [SERVICE ] Begin cmd [connect] [MsgProcessor.cpp:1022]
[2023/07/24 17:24:34.773] [DEBUG ] [ 2] [SERVICE ] pipe id _11, [MsgProcessor.cpp:136]
[2023/07/24 17:24:34.775] [ERROR ] [ 2] [SERVICE ] Init:: failed to create pipe: /tmp/nd_mount_11 [ParentPipe.cpp:502]
[2023/07/24 17:24:34.776] [DEBUG ] [ 2] [SERVICE ] Finish cmd [connect] [MsgProcessor.cpp:1128]
[2023/07/24 17:24:34.776] [DEBUG ] [ 2] [SERVICE ] exec /Applications/NetDrive.App/Contents/Helpers/nd3svc.app/Contents/MacOS/nd3svc [ParentPipe.cpp:100
Please check if there is /tmp folder and files with nd_mount prefix? If so, remove all files with nd_mount prefix and then try mount again.
If you continue to have the issue let’s have a remote session to check the issue.
Before we proceed, may I know your timezone and what time works best for you?
Please provide me with two or more options for the best time so that we can schedule the session accordingly.
Also, to initiate the remote session, please follow these steps:
Thank you, and I look forward to resolving the issue together.
