Looking for Advice on Optimizing BDrive Performance
Hi everyone,
I hope you are all doing well. I have been using BDrive for a while now and I am really impressed with its features. However, I am looking to get the most out of it and was wondering if anyone here has any tips or suggestions for optimizing performance. I was using Google cloud console (GCP) to optimize performance and as per these articles Trouble with docx files when connecting to a WebDAV share what is Google Cloud Console I need to make excel in BDrive features. This is why I need your advice on it.
Specifically, I am interested in any tricks you’ve found useful for speeding up file sync times or improving overall efficiency. Are there any settings or configurations you’d recommend tweaking?
Thanks in advance for your help :slightly_smiling_face:
Dear harshmaan991,
Are you using your own Google API key? Utilizing a personal Google API key can help speed up your Google Drive operations in NetDrive. You can follow the steps in the link below to register your own API key:
Additionally, you can find useful information about NetDrive in the Help section on the NetDrive website: NetDrive | Mount your storage as local drive
For more detailed instructions, you can also refer to the NetDrive Manual, which provides guidance on optimizing your usage of the software.
Best regards.
