NetDrive version: 3.7.687
Windows/Mac Version: windows server 2016 / windows 10
Hi Netdrive,
After our server management created our new server enviremonth netdrive keeps looping at her start screen (blinking logo). Right below it says “initializing” It keeps doing that and won’t start.
Kind regards,
Change Log Level
Get back to DRIVES screen
Changed log level takes effect when you leave SETTINGS screen.
Reproduce your problem !
After changing log level you must repeat your steps to reproduce the problem you have. This time it will be logged in relevant log files.
Send Log File
Within your driv…
Good morning,
NetDrive wont start, so I cannot change the log level. I created a log file from the directory.
See attachment.:
Netdrive_logs.zip (1.1 MB)
Kind regards,
March 11, 2019, 2:01am
6
I reviewed the log files.
The causes of your issue is that ndagent and nd3svc is not running from 22 Feb.
Could you check the status of the processes?
You can refer to the following article.
If the UI is stuck in the splash window after running NetDrive, the service nd3svc.exe or ndagent.exe may not be running.
In this case, check whether nd3svc.exe and ndagent.exe are running by referring to the following.
Press Windows Key + R and type services.msc to launch the Services List.
2.Check “Status” and “Startup Type” of NetDrive3 Agent (Product NetDrive3) and NetDrive3 Service (Product NetDrive3) in the service list.
“Status” should be “Running” and “Startup Type” should…
