We have problems with GoogleDrive cloud connection.
After restarting the server and while it is running, the server loses the connection to the cloud. The settings are distributed to other servers of the same type via the account.
With these servers, there are also sporadic disconnections.
In addition, a WebDav connection to a cloud drive of another provider is used, but this runs error-free and without disconnections.
System
-NetDrive version 3.14.309
-Windows Server 2019 - Windows version 1809
GoogleDrive log entry
[2021/04/28 11:43:20.919] [ERROR ] [ 6752] [SERVICE ] [ nd3 sdk version - child nd3svc : 3.15.393 ] [Child.cpp:129]
Connected drives
Drives in Windows
GoogleDrive settings
Dear webmaster-007b,
nd3svc_Google Drive.log (501.3 KB)
VERBOSE debug log
July 12, 2021, 7:24pm
#4
I got the file you attached and reviewed it.
I recommend to register your own google API Key and secret key because of api rate limitation.
The default api key is shared to the other NetDrive users so it might be very slow.
Please refer to below topic.
NOTE: All users of NetDrive share the same Google Drive API client ID for accessing their files. If your connection suffers from slow download and/or upload please register your own client ID.
1. Open https://console.developers.google.com in your browser and log in to your google account.
2. Click 'Select a project’
3. Click 'NEW PROJECT’
If you have a project already, you can use it.
4. Input project name, Organization and Location then create it.
You need to set…
closed
July 19, 2021, 7:25pm
#5
