I just downloaded NetDrive3 and I’m performing some test on my Windows Server 2012 R2 instance connecting NetDrive with OneDrive Business (using a network drive Z:).
Everytime I drag & drop a file from a local disk to the NetDrive mapped disk, I get an error (please see the attached stamp-screen).
I found a similar issue here: Continuous error 0x800703EE when copying several files to Onedrive but the provided answer does not fit to my case.
Please can someone help me with this issue?
-marcello
January 21, 2021, 6:02am
#2
Hello @iyyoon ,
thank your for your reply.
Finally, I removed NetDrive from my server and I’m going to revoke the trial.Too much issues for my scenario.
Thank you very much for yout interest with my case.
Kind Regards.
-m
January 21, 2021, 9:01pm
#4
Don’t hesitate to contact us.
closed
January 28, 2021, 9:01pm
#5
