I have this error on one computer:
"Please check login credentials again"
Can you help me?
Thanks
Can you help me?
Thanks
Dear miltondossantos,
nd3api_iexplore.exe.zip (6.9 MB)
I send you the log files
I found a clue to the problem in the log file you attached. It seems that a 401 error occurs when connecting to WebDAV.
[2021/04/13 10:39:39.617] [MESSAGE ] [ 2020] [PROTOCOL ] Protocol::Connect >> HTTPS PROPFIND >> 401 : https://miltondossantos.webhop.net:5006(401) - 113ms
[2021/04/13 10:39:39.617] [DEBUG ] [ 2020] [PROTOCOL ] Protocol::Connect >>
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
[2021/04/13 10:39:39.617] [ERROR ] [ 2020] [PROTOCOL ] Protocol::Connect >> ON HTTP 401 : AERROR::ACCESS_DENIED(0x00000018)
The content of the connect result is below.
401 Authorization Required
This server could not verify that you are authorized to access the document requested. Either you supplied the wrong credentials (e.g., bad password), or your browser doesn’t understand how to supply the credentials required.
Could you check your ip is in block list of Synology NAS Server or not.
Please refer to the following topic.
Yes, you are right
the ip adress was blocked by the Synology
Thank you a lot for your help!!!
