Hello I tried to connect dropbox, onedrive and google drive but have no luck at all. Can you please share how to do this in detail.
Thank you
Could you give us more details?
Connection failed while adding drive items? Then please refer to below.
If your issue is not above, please attach debug log files to figure out what is wrong.
Hi Thank you for your answer. I have installed the root certificate and it’s still not working. I will stop at this point and uninstall the software, because I don’t want to waste anymore time. If you can’t produce software which a normal user can’t install without additional work, you are on the wrong path, at least for me. By the way, the error message was the same after installing the root certificate. You may look for more sophisticated users.
Have a nice day
Regards Karl Wild
Did you install the certificate to “Local Machine” location?
I revised the topic. Please try one more time again.
As I mentioned I will not spend anymore time with your product. Produce something usable then approach me again.
Regards Karl Wild
