i’m really suffering problem a with netdrive 3. I’m working for more than one organisation and two of them are working with netdrive business. I can connect flawlessly with one them but it is impossible to connect a second netdrive. The login info seems to be duplicated from the first netdrive and i can not manually change this.
this is super annoying and i’m really losing my confidence in this product.
I have this problem before on the forum but no reply with a solution./
HELP
Hello will.
Which protocol type you have the issue is?
Hello Jyyvoon
The protocol type I’m using for this connection is OneDrive for business
Attached is the debug log file.
What happened is the following:
I have a OneDrive for business with a organisation called Tejaterke. The login and further process works OK
I have another OneDrive for business with an organisation called Handelsmij Cuijpers. When I would like to connect with this OneDrive the program selects automatically the Tejaterke
OneDrive and not the Handelsmij Cuijpers drive
I cannot make a selection or run (preferred) both under different drive letters
And the verbose debug log file
It seems to be not possible to put them in one zip file so here are the separate files:
I think with those 3 you should recognize the problem
Attached a screen dump of the login’s
Thank you
Will
Verzonden: donderdag 7 februari 2019 19:10
nd3log.zip (1.22 MB)
nd3svc_OneDrive for Business(1).log (86.4 KB)
nd3svc_OneDrive for Business.log (249 KB)
nd3api_SnippingTool.exe.log (393 Bytes)
Please refer to following topics.
hello,
again i’ facing the same defect on your software. I can’t connect with onedrive for business. This is now going on for about a year and every timeMS comes up with a update i’m getting into problems. Can’t imagine that i’m the only one with this problem.
can you give me assistance?
regards
Will
