Since the new version i get: “Authentication with WebDAV has failed”. Existing mounts to my synology still work but even if i disconnect them go in and click connect, the give this messages. If i then cancel, i can connect existing once fine. I just am unable to create new ones. I will try installing the old version again…
I reverted back to 3.1.196 the initial release and all is fine now… So it is a bug in the latest version.
We’ve tried to reproduce your problem, but we couldn’t.
Could you send us debug log after reproducing your problem? It will be very helpful to find out what problem is.
We need a whole log file in your case.
- Set log level to DEBUG in settings.
- Compress the C:\ProgramData\NetDrive3 folder to zip it and send us it.
By default, C:\ProgramData folder is hidden.
The url below will help you generate a debug log.
