pedro
September 25, 2022, 8:33pm
1
I’ve been using NetDrive to mount both dropbox and Onedrive volumes for my media server.
The Dropbox volume is now 50TB in size with over 22TB used and the server can no longer read the media files to present them to client players.
Is this expected behavior? Is anyone else seeing similar?
Dear @pedro ,
I think we need to check the log files.
pedro
September 29, 2022, 3:08pm
3
It will take me a day or two to get the logs since I’ll need to disconnect, reconnect, and let the server try to play some media in order to get a full capture of the data you’ll need
pedro
October 1, 2022, 5:51pm
Here are the logs
nd3log.zip (31.9 MB)
pedro
October 1, 2022, 5:55pm
5
BTW, what is the advanced option “As a global drive” for? I can’t find it anywhere in the guides or help
For team licenses, each users mounted drive is not accessible from other users. This option is displayed only for team licenses and if you turn on this option your drive will be accessible from other users.
October 11, 2022, 2:00am
7
