Very often background file uploads do not report the upload percentage correctly. The interface continues to show unrealistic progress until suddenly the file finishes uploading.
I attach a screenshot of an uploading file that has bee
n sitting like this for more than an hour.
Dear fade91it,
Log file attached
nd3svc_Balmy Wave.log (3.4 MB)
April 17, 2021, 5:44pm
