Upgraded to Netdrive3. Windows 10 64, build 18363.535. No connection to DropBox, Onedrive for Business. Just sits and spins.
Dear guidic1,
Continuing the discussion from Upgraded to NetDrive3. Nothing works:
The funny thing is I have two laptops that are litterally twins. I bought two licenses. It works on the second, but not the first. Here are the log filesnd3svc_DCSD OneDrive.zip (7.5 KB) NetDrive3_guidic.zip (11.8 KB)
Dear guidic1,
I looked at the log file but I can’t find the cause of the problem.
Please try uninstalling and reinstalling NetDrive.
If the problem persists, we may be able to solve it through remote access.
Ok. We might try that tomorrow. Like I said, I bought two licenses, and the machines are literally twins. The only exception is Netdrive2 was running on the machine that is now not working.
