Unable to mount the mount point and autmatcally disconnected
unable to mount the mount point and autmatcally disconnected
Thank you for contacting us.
The message stating that the mount point could not be mounted and was automatically disconnected is not enough to determine the exact cause. Could you please provide the following information?
  • The exact NetDrive version you are using
  • Your operating system and version
    For example: Windows 11 24H2 or macOS 15.x
  • The storage service or protocol you are trying to connect to
    For example: Google Drive, OneDrive, WebDAV, or SFTP
  • A screenshot showing the error message
  • The NetDrive log files
Please follow these steps:
Please be aware that the log file does not contain any login credentials.
hi team,
please find the requested details. otherwise please set up a call we will connect and discuss this is bank integration so please resolve the issue asap.
  • The exact NetDrive version you are using : 3.19.14.0
    Windows Server 2022 Datacenter : 21H2
    azure storage container
  • not showing anything on that time for mountin
