As soon as I place a file into my mapped NetDrive, the timestamp on the file is exactly one day ahead of the present time. This is stopping our ERP systems from being able to print from the printer.
tsjeong
September 15, 2021, 12:42pm
2
Dear epicoradmin,
September 22, 2021, 12:43pm
3
