I am trialling the latest version of Netdrive3 to access a blobstore through sftp. connection to the site works however lists all of the home directories with a prefix of "GMT ", if i try to drill down through these directories i get an error (presumably because the folder name isn’t correct). equally if i create a file within this top level the file gets the same prefix, any ideas why i am getting a prefix like this?
- Reproduce the problem.
nd3svc_SFTP.log (224.1 KB)
log attached, thanks
Dear dmcconaghie1,
I have reviewed the log files you attached and have identified the cause of the issue. There seems to be an issue with the File List format when connecting to Azure via SFTP.
We’ll let you know when we fix the problem.
Excellent news, thank you so much!
Dear dmcconaghie1,
We fixed the problem. Please install the new version here.
Thanks, it worked.
good evening, if i upload a file then try to view it through the mapped drive explorer i can only see the first 15 characters of the contents. have i got part of the configuration wrong?
thanks
Dan
Dear dmcconaghie1,
Thanks, it worked.
Dear dmcconaghie1,
Glad to hear it’s working. Thanks for the feedback.
