NetDrive version: 3
Windows/Mac Version: 10
Our client has been using Net Drive 3 for a week or so but now saying the following “I am not convinced with this link as yesterday it was taking about 5 minutes to connect at times.” Is this a known issue or perhaps there are settings that we need to change to stop this from happening?
Cheers,
Guy
October 9, 2018, 9:06pm
2
Hello Guy.
Sorry for late.
I’m afraid there is no option about that.
But If you want to figure out what happened, attache log files at here.
