Hi I am having the same situation as another topic but I don’t see any solution on the post. I am connecting several laps to the same account but one of them today started to send the message: drive: error conectando
These are the last lines on the log:
[2022/08/10 08:45:59.230] [ERROR ] [ 1676] [PROTOCOL ] S3::Connect Failed to listAllBuckets
[2022/08/10 08:46:30.456] [ERROR ] [ 11720] [SERVICE ] [ nd3 sdk version - child nd3svc : 3.16.667 ] [Child.cpp:129]
Dear elmikebd,
August 11, 2022, 5:52pm
This topic was automatically closed 60 minutes after the last reply. New replies are no longer allowed.
