Prodblem with Secure WebDav
Hi there,
i’ve got Problems with Secure WebDAV. Protocoll-Error.
I’ll tried to use diffrent way to connect
https://domain (without Port and with Port 443) , get Message to check the Connection
http://domain (with Port 443), Connection established, but i get Error Protocol::GetFileList >> HTTP 400
[2018/12/21 07:04:14.727] [ERROR ].
Do anyone have some tips for me?
Hello farlis
Could you check that what your proper webdav port is?
I guess that the port 80 and 443 are for http not webdav on your webdav server.
If your webdav server is Synology NAS, default webdav ports are 5005 and 5006(with ssl).
i try to connect to an WebServer with Unix-OS.
The right Connection-String ist https://domain/subfolder/. This works with any Webbrowser, but not with the NetDrive3. I can only save the Connectionsstring without using SSL and set the Port to 443.
Then, could you attache debug log files to figure out what happened?
