I’m having an abnormal problem in a folder on the qnap server. In particular, copying an excel file inside the folder, the same results as a tmp file (accessing via netdrive) - by accessing the server locally, there is no anomaly in the file.
by disconnecting and reconnecting netdrive, the problem is solved
can you tell me the reason?
thank you
January 23, 2020, 8:11pm
2
Could you explain more details what “the same results as a tmp file” is?
And attach debug log files to figure out what happened after reproducing it.
January 30, 2020, 8:11pm
3
