Good morning,
I have a problem with SFTP connection. Not all folders are displayed. There were no problems before. There are no problems with other SFTP connection programs.
Thank you
Good morning,
Thank you
Could you change charset to another one?
You can change it pressing “OPTION” button in configure of a drive item.
If your issue persists, could you attach debug log files to figure out what happened?
Thank you for your reply. Currently I have redone config and it is in place. OK problem for now.
Thank you
