PDF corruption using NetDrive 3 on Mac OS 14
We are using NetDrive to mount over WebDAV our company’s file storage system.
On a Mac with an Apple chip running OS 14, PDFs corrupt when we use the markup tools within Adobe Reader/Acrobat. This problem does not appear from Windows machines which use the same Adobe software.
Any suggestions?
Archive.zip (3.6 MB)
Also uploading screenshots of the activity within Adobe that leads to the error.
Dear kh_user-2ea2,
Does the issue occur when editing PDF files on a local drive, not a drive mounted via NetDrive? For example, please check if the PDF files get corrupted when edited with Adobe Reader/Acrobat on a local drive.
This information will help us better understand the cause of the issue.
Best regards
Hi.
This only happens via NetDrive.
When commenting on PDFs natively there is no problem. Nor when I access our server via MacOS protocol - Connect to Network.
Thanks for looking into this.
Khuzema Hussain
Partner
07723 329 700
Collective Works LLP
Architecture & Design Studio
Unit 2.01, 60 Grays Inn Road
London WC1X 8LU
http://www.collectiveworks.net
Dear kh_user-2ea2,
Thank you for providing additional information. We have analyzed the logs you sent, but we did not find any specific issues. We will need to investigate further to find a solution. In the meantime, please ensure that you have the latest version of NetDrive installed. You can download the latest version from the link below:
Download NetDrive 3.18.751
Best regards
