I am unable to use netdrive 3. The password field is unactive
Can you help me
Dear ggu,
Could you explain in more detail how it doesn’t work?
I would appreciate it if you send me a log file. Then we can find clues more easily about your problem.
The log files NetDrive3_Setup.log and NetDrive3_Install.log are in the path %TEMP%\Bdrive.
Above path is “C:\Users\username\AppData\Local\Temp\Bdrive”.
Here are the log files.
As said, I use Remote.it since some monthes, and I am trying the
veta version witch seems to allow a faster connection for CLI.
I have downloaded the mentionned file, then I have installed,
butr when I lauche the app, the screen close some seconds later.
Kind regards
NetDrive3_Install.log (1.35 MB)
NetDrive3_Setup.log (9.85 KB)
Dear ggu,
Could you check Firewall and Task Manager?
Please check your Windows Defender Firewall.
Check the NetDrive3 Services in the Services tab of the Task Manager.
If it’s stopped, start it.
The following topic will be helpful to you.
