Hi
I had the same problem, I downloaded and installed 3.1.247 and problem still there,the drives are not in installed
hope you clear this, as I dont have access to my remote NAS
Thanks
Hi
Thanks
Dear dwayneh
Could you check this issue after downloading and installing from the following url?
http://files.bdrive.com/netdrive/builds/NetDrive3_Setup-3.1.247.exe
Dear jl-talavera
Set the LOG LEVEL to DEBUG in SETTINGS and reproduce the problem.
Then send the file C:\ProgramData\NetDrive3\nd3log\ndagent.log to me via Private Message.
It will be helpful to figure out what your problem is.
