NetDrive version:
Windows Version:
Hi, I have purchased 1x lic under the email address - technetdrive@thewheelofbrisbane.com.au. However I am NOT able to create a DRIVE CONNECTION. No Error, just cannot click on the CONNECT button (greyed out) when creating a new drive connection. Please help.
June 19, 2019, 1:01am
2
Could you set a host url to “http://host:5005 ” or https://host:5006 " ?
If your issue persists, could you attach debug log files to figure out what happened?
