NetDrive3 could not connect to Bdrive Server
Hello, I am having this error when I try to login with my second laptop (I have 2 licenses) to NetDrive3.
I have uninstalled/installed the application again with no luck.
Once I click to go proxy settings, whatever settings I choose, I can’t login. And when I reach the login screen, I try to connect through my Google credentials and it gets stuck.
Dear petros-stavridi,
NetDrive3_vShannon.zip (681.9 KB)
Here it is, thanks!
Any updates on this one please?
NetDrive has not been able to connect to the Bdrive Server since 18:55 on May 30th.
Has there been any change in the network environment?
Yes, since then I started connecting through a 4G network. Before it was my home VDSL line. Should I care for a specific setting in firewall/proxy?
Thanks!
Please refer to below topic.
I am not behind a proxy server though. Can you please advise how to proceed?
I’m not sure because I have no idea with your environment.
But I can help you having a remote session.
If you want, let me know your AnyDesk address and the time you are available with UTC.
It can be downloaded from Download AnyDesk for Free.
Reards.
