We are having some issues with NetDrive showing the swedish characters åäö as ? in the filenames which makes the files impossible to open.
Example: D:\Path\ToFolder\L?ne?kningJatack.xml
when it should be D:\Path\ToFolder\LöneökningJatack.xml
If we change the charset in NetDrive to UTF-8 no files are shown at all, only folders.
If we change the charset to Autodetect, the filenames shows with wrong characters.
If we change the charset to Local charset, the filenames shows with wrong characters.
The language for non-Unicode programs in the Windows OS is set to Swedish.
