Dear Net Drive Team,
Recently we find out that one of our terminal servers having lack of RAM. During short diagnostic we can see that Net Drive process “Bdrive nd3svc.exe” takes too much RAM and sometimes it takes from 6 to 8 Gb’s of RAM.
Can you please explain why it’s happening and can we control it?
NetDrive version is 3.8.915
Dear it-renewals,
May 27, 2020, 11:51pm
3
