After installing netdrive on MacOS, launched the NetDrive for the first time. I tried to access Google Drive, and it hangs. From that point, the application hangs after launch. Shows the splash screen and NetDrive goes unresponsive.
1/ I tried uninstalling and reinstalling, same result. Nothing happens on launch, and it goes into not responding. Had to Force Quit. Can’t give you a log since the app doesn’t open to give you the option to create a log.
2/ how do I do a clean uninstall that clears out all fo the initial settings
3/ why isn’t it working? I’m only using Google drive, and would like to mount the drive.
