Hello Users and Support,
I have very often the issue, that Netdrive crash on my Windows10. I reboot my machine than.
If it is restarted, I want to login by open NetDrive3. But as you can see in my screenshot there is no
login possible. Some time later (>30min) and recheck login I am logged in.
How I can fix it`?
February 27, 2022, 8:34pm
2
Could you attach debug log fils to figure out what happened after setting a log lovel to VERBOSE?
March 6, 2022, 8:35pm
