When trying to connect to my drives, I get the message : “Netdrive is not initialized”.
I’m using the latest software version and ave tried to reboot my PC…
ysh
July 26, 2018, 5:02am
#4
Change Log Level
Get back to DRIVES screen
Changed log level takes effect when you leave SETTINGS screen.
Reproduce your problem !
After changing log level you must repeat your steps to reproduce the problem you have. This time it will be logged in relevant log files.
Send Log File
Within your driv…
This morning I do not have the problem anymore.
I do not know what happened…
Thanks anyway for your support,
ysh
July 26, 2018, 5:47am
#6
Thanks for letting us know. I’m closing this topic.
Thanks for using NetDrive.
