ssirin
November 5, 2019, 4:25pm
1
Just noticed this bug on our server. When someone opens an .XLS file over a Netdrive WebDav share and makes and edit and saves, the file corrupts to a xxxxx.tmp file of the same size.
This doesn’t occur locally, only over the netdrive webdav share. We are using Office 365 version of Excel.
Thanks
Can you send us the debug log files when the issue happens?
It will help us to figure out what caused the problem.
Change Log Level
Get back to DRIVES screen
Changed log level takes effect when you leave SETTINGS screen.
Reproduce your problem !
After changing log level you must repeat your steps to reproduce the problem you have. This time it will be logged in relevant log files.
Send Log File
Within your driv…
ssirin
November 6, 2019, 4:57pm
netdrivelogs.zip (159.0 KB)
See attached for the logs. The relevant log is “nd3svc_GC Accounting”
Thanks
ssirin
November 7, 2019, 1:02pm
5
Just following up on this, thanks.
When our engineer finishes analyzing the log file I will come back to you.
Thanks for the log file.
November 11, 2019, 7:52am
7
Hello customer.
I reviewed your log files and found out http 500 error returned from webdav server.
Http 500 error means “server error”.
I’m not sure what problem is on server yet.
I will research about this issue and if I recognize something, I will let you know too.
