I cannot download a pdf file and save it directly to OneDrive/Dropbox/Amazon Drive which are handled by NetDrive 3. NetDrive 2 used to have this problem but was fixed and worked perfectly. It is a pain to have to download many files each day to a local hard drive – then using file manager to transfer to One Drive or Dropbox or Amazon Drive. Can you fix this up for me? Thanks
I have the same problem with WebDav, worked fine with Netdrive 2
If you give me the debug log, It will be very helpful to figure out.
You can refer to this article to send the debug log.
A post was split to a new topic: NetDrive 3 error in saving PDF files
