Hello!
What could be wrong, that after I connect to the FTP place, it don’t show any files/folder at all. The station is empty! When I push the browse button, I get an error “Failed to get file list”
But when I try to connect to the same FTp with Filezilla, it shows all the files/folder
Please set the log level to VERBOSE
Reproduce the problem.
Afterward, please follow the instructions in the following link to send us the debug log file:
Hello!
Here is the files, hope that could help you……….
Have tried both FTP and SFTP, no files/folder is showing…………
Kåre!
nd3svc_FTP.log (1.61 MB)
nd3svc_FTP1.log (143 KB)
Sorry for the delay. From the log file it appears that port settings are causing the problem. Do you use active mode?
April 14, 2023, 3:46am
6
