Netdrive 3 does not load local drive on Win 11 login
Netdrive 3.18.1147 does not load a local drive on login or when activated manually via the DRIVE or Config options. The problem is intermittent and Will load Netdrive 3 in about 1 in 10 tries including after computer shutdown. I can upload a zip file of the logs you require if you need it.
Cheers, Graham
Hello Graham,
We tested version 3.18.1147 on Windows 11, and the local drive mounts correctly here.
Your issue may be caused by the NetDrive service not running.
Please check the service status as follows:
  1. Press Windows + R, type services.msc, and press Enter.
  2. Find “NetDrive 3 Service” or “nd3svc” in the list.
  3. If the status is not “Running”, right-click it and choose “Start”.
  4. Then try launching NetDrive again.
If the service is already running and the issue persists,
please send us your log files for further analysis.
We’ll review the logs carefully and get back to you with a detailed explanation.
Thank you very much for your cooperation.
