NetDrive is not connecting automatically anymore. When I try to start it manually the login screen starts but I can not enter the password. Nevertheless the screen is not completly frozen cause I can edit the proxy settings etc… In the services section I can see that the ndagent and nd3svc process are not started. After starting them manually netdrive connects automatically. After a reboot I have to do the manual procedure again. I think it might be like this since the last major Win10 update but am not 100% sure. Do you have any idea what might prevent the services from starting automatically?
Are you using anti-virus program or anti-malware program to protect pc?
They might prevent execution of ndagent and nd3svc.
Or the issue appeared on a pc infected with “BrowserModifier: Win32 / Soctuseer”.
The following topic may be helpful to you.
thanks for the quick reply. The change of the startup type to “automatic (dely start)” solved the problem.
Thx!
