Nd3svc crashes with ucrtbase.dll fault 0xc0000409
Good day,
Will you please help with this service crash? Thank you.
Description | System Information
The nd3svc application has crashed twice in the last week with an identical exception code / module on Windows Server 2016 Datacenter.
Expected behavior: nd3svc should not crash.
Stacktrace
Faulting application name: nd3svc.exe, version: 3.15.450.1, time stamp: 0x618974b5
Faulting module name: ucrtbase.dll, version: 10.0.14393.3659, time stamp: 0x5e9140a1
Exception code: 0xc0000409
Fault offset: 0x000000000006de4e
Faulting process id: 0x8b8
Faulting application start time: 0x01d8430697b5eb0d
Faulting application path: C:\Program Files (x86)\Bdrive\NetDrive3\x64\nd3svc.exe
Faulting module path: C:\WINDOWS\System32\ucrtbase.dll
Report Id: 30e82181-73e6-43aa-b168-515995415456
Faulting package full name:
Faulting package-relative application ID:
And If there is a dmp file in the path C:\ProgramData\NetDrive3\Dumps, please attach it too.
Good day, jyyoon.
I was not able to replicate this issue, and it has not happened since I reported it. I’ll look for a dump file next time it happens. I found a few dump files from recent server reboots where the user did not stop the service, but nothing from the time of the issue.
This is not related to the service crash, but if it is of interest to you, here is what happens when the server reboots without stopping the service cleanly:
Unable to load image C:\Program Files (x86)\Bdrive\NetDrive3\x64\libzmq.dll, Win32 error 0n2
*** WARNING: Unable to verify timestamp for libzmq.dll
*** ERROR: Module load completed but symbols could not be loaded for libzmq.dll
rax=00004d8d84de28d1 rbx=000002a0b1a2d210 rcx=0000000000000000
rdx=000000e4c0dff840 rsi=0000000000000000 rdi=0000000000000000
rip=00007ffd9b2d4be0 rsp=000000e4c0dff7d0 rbp=000000e4c0dff840
r8=0000000000000000 r9=000000e4c0dff910 r10=0000000000000001
r11=000000e4c0dff940 r12=0000000000000003 r13=000000e4c0dffa50
r14=000000e4c0dff910 r15=000000e4c0dff960
iopl=0 nv up ei pl zr na po nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010246
libzmq+0x34be0:
00007ffd9b2d4be0 488b01 mov rax,qword ptr [rcx] ds:0000000000000000=???
Thank you
Thank you for feedback.
If the issue occurs again, contact us again please.
