jensre
February 27, 2018, 8:47pm
1
Hello, I cannot connect to OneDrive or to Google Drive because I am getting a “Mount Eror” after pressing on the connect button. Is there a workround for this issue ?
Alex
March 7, 2018, 5:26am
We need more clue to analyze your problem.
What OS/OS version do you have?
After setting the log level to VERBOSE, can you send us a log file?
