This did not appear in the beta but it’s there now and it’s HUGE.
Server 2016, fresh upgrade of NetDrive 2 to NetDrive 3 after un-install of previous version
Connected all of the drives used during Beta test:
(1) OneDrive
(2) DropBox (different accounts)
(2) OneDrive for Business (different Accounts)
Initiated a copy of 96GB of files from local drive to DropBox storage
Indicated 11 minutes to copy (impossible, even with 300mbs FIOS)
~45 minutes into the copy, all drive disappeared but NetDrive3 thinks they are still connected
I am not sure at this moment, but looks like NetDrive3 have a bug, when copied file size is over 8GB. But, may be not. Not sure at this moment. ‘just my 2 cents’ as user. (I have same effect, file is copied to chache, NetDrive (till restart) shows, that file is on target drive, but file not copied really… )
