Hello Dears,
I need your great support. I start working on MacBook with macOS Catalina.
Installed netdrive3 ver 3.10.139 and not working. Problem is few minutes after connected to server.
I get message from netdriver that “netdrive unxpected stopped” and I can not do anything.
I try few versions of netdrive3 and I do not know how to solve it.
Please help
best regards
GK
Dear GK,
Dear Tsjeaong, I did as you wrote (changed log level to VERBOSE) but problem still occur. I do not know where can I get debug log file in NetDrive?
best regards
GK
Dear GK,
The path to the log file is as follows on the Mac.
/Users/<User-ID>/Library/Logs/NetDrive3
Dear Tsjeong,
Found this folder but I do not see there any “debug log file”.
Could you let me know which one file shal I send you?
best regards
GK
Dear GK,
Compress and send all the files in the path /Users//Library/Logs/NetDrive3/nd3log.
More details are in the topics below.
Dear Tsjeong, please see attached all files in zip.
best regards
GKArchiwum.zip (178.0 KB)
July 27, 2020, 10:38pm
9
I got the files you attached and reviewed them.
I found the moment NetDrive suddenly crashed.
Can we have a remote session to figure out what’s problem?
We can have a remote session via AnyDesk.
If you want, let me know your AnyDesk address and the time you are available.
You can install AnyDesk after downloading from https://anydesk.com/en/downloads
This topic can be shown to only our staff.
Hello Jyyoon,
I’m available now and next one hour if possible to connect please : 846 741 916
best regards
GK
Hello, when we can connect to solve this problem?
best regards
GK
August 7, 2020, 2:05am
13
Sorry for late. I missed this topic.
How about next monday?
I will connect to you if let me know the time you are available.
August 11, 2020, 9:27pm
14
I wonder what time you are available to have a remote session.
Please let me know and let’s arrange it.
August 18, 2020, 9:27pm
15
