i am unable to work with jpeg files. i can upload them to Amazon Drive and OneDrive via a mapped drive, but when i try to access them i get errors. please advise.
After setting the log level to DEBUG, please reproduce the problem and send us the debug log file :
Change Log Level
Get back to DRIVES screen
Changed log level takes effect when you leave SETTINGS screen.
Reproduce your problem !
After changing log level you must repeat your steps to reproduce the problem you have. This time it will be logged in relevant log files.
Send Log File
Within your driv…
Thank you for the feedback.
