pedro
February 8, 2021, 7:31pm
1
It’s taken quite a bit of time to narrow this down but NetDrive3 on Big Sur causes memory problems, system crashes, and blocks shutdown & restart.
Symptom #1: System reports that user memory is exhausted, when it’s not but it keeps prompting to force close applications until NetDrive3 is closed.
Symptom #2: Crashes with dumps indicating problems with smbfs. (This may be due to NetDrive3 being used with Tuxera NTFS on the same machine)
Symptom #3: Restart hangs on trying to close NetDrive3, required hard power-down to get past it.
Forgot to note that I had to remove the product to restore system stability.
February 14, 2021, 10:41pm
2
Thank you for feedback.
It seems that there were so many file I/O requests on the drive mounted with NetDrive.
Could you attach debug log files to figure out what happened if possible?
pedro
February 16, 2021, 2:23am
3
I’m afraid that I can’t provide logs for this now since I had to remove the product in order to stabilize my iMac.
I’ll try it again with the next build.
pedro
February 16, 2021, 2:25am
I doubt that there were any file i/o requests involved since I had no drives mounted. Just having the product installed and active was enough to cause issues for me.
February 17, 2021, 1:15am
5
I am researching about this issue.
