We’re trying to connect a SharePoint Site to NetDrive but upon connecting and login onto Microsoft 365 Netdrive throws an error:
Authentication with TEAM_SharePoint has failed.
If I check the logs the following pops up:
[2023/11/27 13:39:10.751] [DEBUG ] [ 51836] [SERVICE ] Begin cmd [protocol_create] [c:\buildbot\slave-win\netdrive3_release\netdrive3_sdk\nd3svc\msgprocessor.cpp:1022]
[2023/11/27 13:39:10.752] [DEBUG ] [ 51836] [PROTOCOL ] SHAREPOINT::SharePoint::Connect called
[2023/11/27 13:39:10.752] [DEBUG ] [ 51836] [PROTOCOL ] SHAREPOINT::SharePoint::Connect disable_async_filelist_ [0]
[2023/11/27 13:39:10.752] [DEBUG ] [ 51836] [PROTOCOL ] SHAREPOINT::SharePoint::Connect async_filelist_ [0]
[2023/11/27 13:39:10.752] [DEBUG ] [ 51836] [PROTOCOL ] SHAREPOINT::SharePoint::Connect use_get_changes_ [1]
[2023/11/27 13:39:10.753] [DEBUG ] [ 51836] [PROTOCOL ] Using Client ID : 87e2c38e-0eea-4b8b-b95c-a8e9d23e80e2
[2023/11/27 13:39:10.753] [DEBUG ] [ 51836] [PROTOCOL ] SHAREPOINT::About::Process started
[2023/11/27 13:39:10.789] [ERROR ] [ 51836] [PROTOCOL ] SHAREPOINT::About::Process >> SSL connect error(35)
[2023/11/27 13:39:10.789] [DEBUG ] [ 51836] [SERVICE ] Finish cmd [protocol_create] [c:\buildbot\slave-win\netdrive3_release\netdrive3_sdk\nd3svc\msgprocessor.cpp:1128]
Can someone clarify why this is happening?
What version of NetDrive do you use?
Please install following version and reproduce the issue with VERBOSE log level.
Please set the log level to VERBOSE
Reproduce the problem.
Afterward, please follow the instructions in the following link to send us the debug log file:
Hi Support,
See logs attached.
nd3api.exe.zip (40.5 KB)
@support1 Could you get back to this?
Sorry that I didn’t attached a link to a new version which generates more logs on the SSL error.
Please install following version and reproduce the problem.
Sorry for the late reply. I missed your topic.
https://downloads.bdrive.com/netdrive/builds/4aa14b6293484263836e1d570899ed50/NetDrive3_Setup-3.17.1022.exe
@support1
See new files attached
NetDrive3.zip (5.7 MB)
Sorry for the late reply. We are working on the issue. We will build a new version with recent libcurl and dependent libraries and post a download link here.
Do you have an ETA on when this new version will become available? Right now, we can’t use the product where we initially purchased it for.
We apologize for the delay. During the process of updating libcurl and its dependent libraries, we encountered a need to upgrade our development tools, which unexpectedly resulted in complications within other modules. We anticipate requiring a few additional days to resolve these issues.
I will promptly share the download link in this space as soon as it becomes available.
December 28, 2023, 3:04am
13
