Issue with NetDrive 3.18.751 on macOS 14.5 - “Mount Process Not Executed” Error
Hi there,
I am currently using macOS 14.5 and have installed NetDrive version 3.18.751. However, I am experiencing an issue where the software fails to mount successfully. The error message I receive is in Chinese and translates to “未执行挂载进程” (which roughly means “Mount Process Not Executed”).
Could you please provide guidance or a solution to resolve this issue?
Thank you for your assistance.
Best regards
Dear truthshalf,
Thank you for reaching out regarding the “Mount Process Not Executed” error (“未执行挂载进程”) you are experiencing with NetDrive version 3.18.751 on macOS 14.5.
The message means NetDrive process which handles mounting does not executed.
Did you changed SIP of your Mac?
Please try the following steps to resolve the issue:
Best regards.
